JavaScript操作cookie
2010年9月2日 10:11 本文热度 10495
写入和读取Cookie是一种常见的功能,可惜JavaScript对此的直接支持并不算完善,下面是几个操作Cookie的函数,用起来还是蛮方便的。
// utility function to retrieve an expiration date in proper
// format; pass three integer parameters for the number of days, hours,
// and minutes from now you want the cookie to expire (or negative
// values for a past date); all three parameters are required,
// so use zeros where appropriate
function getExpDate(days, hours, minutes) {
    var expDate = new Date( );
    if (typeof days == "number" && typeof hours == "number" &&
        typeof hours == "number") {
        expDate.setDate(expDate.getDate( ) + parseInt(days));
        expDate.setHours(expDate.getHours( ) + parseInt(hours));
        expDate.setMinutes(expDate.getMinutes( ) + parseInt(minutes));
        return expDate.toGMTString( );
// utility function called by getCookie( )
function getCookieval_r(offset) {
    var endstr = document.cookie.indexOf (";", offset);
    if (endstr == -1) {
        endstr = document.cookie.length;
    return unescape(document.cookie.substring(offset, endstr));
// primary function to retrieve cookie by name
function getCookie(name) {
    var arg = name + "=";
    var alen = arg.length;
    var clen = document.cookie.length;
    var i = 0;
    while (i < clen) {
        var j = i + alen;
        if (document.cookie.substring(i, j) == arg) {
            return getCookieval_r(j);
        i = document.cookie.indexOf(" ", i) + 1;
        if (i == 0) break;
    return "";
// store cookie value with optional details as needed
function setCookie(name, value, expires, path, domain, secure) {
    document.cookie = name + "=" + escape (value) +
        ((expires) ? "; expires=" + expires : "") +
        ((path) ? "; path=" + path : "") +
        ((domain) ? "; domain=" + domain : "") +
        ((secure) ? "; secure" : "");
// remove the cookie by setting ancient expiration date
function deleteCookie(name,path,domain) {
    if (getCookie(name)) {
            "; expires=Thu, 01-Jan-70 00:00:01 GMT";
将上面的几个js命名为cookie.js,下面演示其基本用法
<script type="text/javascript" src="cookie.js"></script>
<script type="text/javascript">
   function foo()
         var name = document.getElementByIdx("name").value;
         if(name)
              setCookie("name",name);
         document.getElementByIdx("show").innerHTML+=("NEWEST NAME :"+ getCookie("name") + "<br>");
</script>
Chapter 1.9 example
<br>
<input type="text" id="name" size="20" />
<input type="button" value="setCookie" onclick="foo()" />
<div id="show"></div>
可以同时开两个窗口看看,输入框不输入值,按按钮相当于察看当前cookie。
该文章在 2010/9/2 10:11:07 编辑过
