[点晴永久免费OA]自定义的加密与解密
2020年3月3日 1:52 本文热度 7865
using System;
using System.Security.Cryptography;
using System.IO;
using System.Text;
class EncryptionAndDissection
    //加密:
    public static string Encrypting(string strSource)
        //把字符串放到byte数组中
        byte[] bytIn = System.Text.Encoding.Default.GetBytes(strSource);
        //建立加密对象的密钥和偏移量
        byte[] iv = { 102, 16, 93, 156, 78, 4, 218, 32 };//定义偏移量
        byte[] key = { 55, 103, 246, 79, 36, 99, 167, 3 };//定义密钥
        //实例DES加密类
        DESCryptoServiceProvider mobjCryptoService = new DESCryptoServiceProvider();
        mobjCryptoService.Key = iv;
        mobjCryptoService.IV = key;
        ICryptoTransform encrypto = mobjCryptoService.CreateEncryptor();
        //实例MemoryStream流加密密文件
        System.IO.MemoryStream ms = new System.IO.MemoryStream();
        CryptoStream cs = new CryptoStream(ms, encrypto, CryptoStreamMode.Write);
        cs.Write(bytIn, 0, bytIn.Length);
        cs.FlushFinalBlock();
        return System.Convert.ToBase64String(ms.ToArray());
    //解密:
    public static string Decrypting(string Source)
        try
            //将解密字符串转换成字节数组
            byte[] bytIn = System.Convert.FromBase64String(Source);
            //给出解密的密钥和偏移量,密钥和偏移量必须与加密时的密钥和偏移量相同
            //实例流进行解密
            System.IO.MemoryStream ms = new System.IO.MemoryStream(bytIn, 0, bytIn.Length);
            ICryptoTransform encrypto = mobjCryptoService.CreateDecryptor();
            CryptoStream cs = new CryptoStream(ms, encrypto, CryptoStreamMode.Read);
            StreamReader strd = new StreamReader(cs, Encoding.Default);
            return strd.ReadToEnd();
        catch (Exception ex)
            throw new Exception("在文件解密的时候出现错误!错误提示: \n" + ex.Message);
该文章在 2020/3/3 1:52:04 编辑过
