[点晴永久免费OA]C#百度OCR身份证图片识别提取信息
2020年4月24日 17:19 本文热度 10029
之前写了一篇利用百度OCR进行本地和网络图片识别文字的文章,点击查看。今天补充识别身份证图片的文章及demo
源码地址:https://download.csdn.net/download/horseroll/10922409
效果图展示:
请求参数:
返回参数:
1.先引用AIPSDK.dll和Newtonsoft.Json.dll这两个DLL
然后在全局变量中声明变量,在窗体加载事件中new个类,传入API_KEY和SECRET_KEY
string API_KEY = "cohIahxAt7HveHLYSHYK6G5N";
string SECRET_KEY = "e8SAsDIWSK9NPUKviYiPQNlfaVDXQSY5";
private void frm_IDCardImgToTxt_Load(object sender, EventArgs e)
    client = new Baidu.Aip.Ocr.Ocr(API_KEY, SECRET_KEY);
    client.Timeout = 60000;  // 修改超时时间
2.传入图片地址,识别图片,返回识别结果
/// <summary>
/// 身份证识别
/// </summary>
/// <param name="filename"></param>
/// <returns></returns>
public string IdcardDemo(string filename)
    bool cardjiaodu = cbjiaodu.Text == "true" ? true : false;
    string cardzhengfan = cbzhengfan.Text == "front" ? "front" : "back";
    bool cardfengxian = cbfengxian.Text == "true" ? true : false;
    var image = File.ReadAllBytes(filename);
    var idCardSide = "back";
    // 调用身份证识别,可能会抛出网络等异常,请使用try/catch捕获
    var result = client.Idcard(image, idCardSide);
    Console.WriteLine(result);
    // 如果有可选参数
    var options = new Dictionary<string, object>{
{"detect_direction", cardjiaodu.ToString()},
{"detect_risk", cardfengxian.ToString()},
        {"id_card_side",cardzhengfan.ToString() }
    // 带参数调用身份证识别
    result = client.Idcard(image, idCardSide, options);
    return result.ToString();
3.识别后的json内容进行输出
/// <summary>
/// 在界面上显示
/// </summary>
/// <param name="returnstr">json内容</param>
public void WriteTo(string returnstr)
    try
        ReturnJsonForCard rj = CYQ.Data.Tool.JsonHelper.ToEntity<ReturnJsonForCard>(returnstr);
        AReturnJsonForCard acj = CYQ.Data.Tool.JsonHelper.ToEntity<AReturnJsonForCard>(rj.words_result);
        string resultstr = "";
        resultstr += "姓名:"+acj.姓名.words + "\r\n"+ "性别:" + acj.性别.words + "\r\n"+ "民族:" + acj.民族.words + "\r\n"+ "出生:" + acj.出生.words + "\r\n"+ "住址:" + acj.住址.words + "\r\n"+ "公民身份号码:" + acj.公民身份号码.words + "\r\n";
        string card_direction = "";
        if(rj.direction=="-1")
            card_direction = "未定义";
        else if (rj.direction == "0")
            card_direction = "正向";
        else if (rj.direction == "1")
            card_direction = "逆时针90度";
        else if (rj.direction == "2")
            card_direction = "逆时针180度";
        else if (rj.direction == "3")
            card_direction = "逆时针270度";
        resultstr += "图像方向:" + card_direction + "\r\n";
        string card_image_status = "";
        if(rj.image_status=="normal")
            card_image_status = "识别正常";
        else if(rj.image_status == "reversed_side")
            card_image_status = "身份证正反面颠倒";
        else if (rj.image_status == "non_idcard")
            card_image_status = "上传的图片中不包含身份证";
        else if (rj.image_status == "blurred")
            card_image_status = "身份证模糊";
        else if (rj.image_status == "other_type_card")
            card_image_status = "其他类型证照";
        else if (rj.image_status == "over_exposure")
            card_image_status = "身份证关键字段反光或过曝";
        else if (rj.image_status == "unknown")
            card_image_status = "未知状态";
        resultstr += "识别状态:" + card_image_status + "\r\n";
        string card_risk_type = "";
        if (rj.risk_type == "normal")
            card_risk_type = "正常";
        else if(rj.risk_type == "copy")
            card_risk_type = "复印件";
        else if (rj.risk_type == "temporary")
            card_risk_type = "临时身份证";
        else if (rj.risk_type == "screen")
            card_risk_type = "翻拍";
        else if (rj.risk_type == "unknown")
            card_risk_type = "其他未知情况";
        resultstr += "识别身份证类型:" + card_risk_type + "\r\n";
        resultstr += "图片编辑工具:" + rj.edit_tool + "\r\n";
        richTextBox1.Clear();
        richTextBox1.AppendText(resultstr);
    catch (Exception ex)
        MessageBox.Show("解析出错,出错原因:" + ex.Message);
4.json字符串的类
using System;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace 百度OCR
    public class ReturnJsonForCard
        public string log_id { get; set; }
        public string direction { get; set; }
        public string image_status { get; set; }
        public string risk_type { get; set; }
        public string edit_tool { get; set; }
        public string words_result_num { get; set; }
        public string words_result { get; set; }
    public class AReturnJsonForCard
        public BReturnJsonForCard 住址 { get; set; }
        public BReturnJsonForCard 出生 { get; set; }
        public BReturnJsonForCard 姓名 { get; set; }
        public BReturnJsonForCard 公民身份号码 { get; set; }
        public BReturnJsonForCard 性别 { get; set; }
        public BReturnJsonForCard 民族 { get; set; }
    public class BReturnJsonForCard
        public string location { get; set; }
        public string words { get; set; }
该文章在 2020/4/24 17:24:57 编辑过
