C# WinForm程序来执行控制台命令的源代码
2021年2月4日 16:28 本文热度 8940
C# WinForm命令行[coonmajia]的用法演示,使用WinForm程序来执行控制台命令的源代码,将CMD可视化,变成Windows窗体的形式,究竟是如何实现的呢?看一下源码就知道了。相关代码片断:
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
using System.Diagnostics;
using System.IO;
namespace WinForm执行控制台命令
    public partial class Form1 : Form
        Process p;
        StreamWriter input;
        public Form1()
            InitializeComponent();
            p = new Process();
            p.StartInfo.FileName = "cmd.exe";
            p.StartInfo.UseShellExecute = false;
            p.StartInfo.CreateNoWindow = true;
            p.StartInfo.RedirectStandardInput = true;
            p.StartInfo.RedirectStandardOutput = true;
            p.OutputDataReceived += new DataReceivedEventHandler(p_OutputDataReceived);
            p.Start();
            input = p.StandardInput;
            p.BeginOutputReadLine();
        void p_OutputDataReceived(object sender, DataReceivedEventArgs e)
            update(e.Data + Environment.NewLine);
        private void button1_Click(object sender, EventArgs e)
            input.WriteLine(textBox1.Text);
            textBox1.SelectAll();
        private void Form1_FormClosed(object sender, FormClosedEventArgs e)
            p.Close();
        delegate void updateDelegate(string msg);
        void update(string msg)
            if (this.InvokeRequired)
                Invoke(new updateDelegate(update), new object[] { msg });
            else
                textBox2.Text += msg;
                textBox2.SelectionStart = textBox2.Text.Length - 1;
                textBox2.ScrollToCaret();
该文章在 2021/2/4 16:28:08 编辑过
