C# 关闭占用指定端口的程序(解决端口号被占用问题)
2021年2月21日 17:50 本文热度 9564
【实例简介】请右键以管理员身份运行该程序
【实例截图】
【核心代码】
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
using DSkinTheme;
using System;
using System.Data;
using System.Diagnostics;
using System.Linq;
using System.Text;
using System.Text.RegularExpressions;
using System.Threading.Tasks;
namespace ConsoleApp2
    public class Program
            // RestClient restClient = new RestClient();
            //// restClient.EndPoint = "http://192.168.1.100:5115/chaipx";
            // string data = "/services/realtime/rainfall/getrainbyhour?date=2017-09-15&adcd=130501,130521,130522,130523,130524,130525,130526,130527,130528,130529,130530,130531,130532,130533,130534,130535,130581,130582,&stcdOrStnm=X&systemTypes=11,13,12,&column=24&sign=1&ly=21,22,";
           // string ii = restClient.doGet(data);
            //以上为RestClient类get使用实例 post可自己进源码查看
            Console.Write("请输入端口号:");
           string port = Console.ReadLine();
            Process pro = new Process();
            // 设置命令行、参数
            pro.StartInfo.FileName = "cmd.exe";
            pro.StartInfo.UseShellExecute = false;
            pro.StartInfo.RedirectStandardInput = true;
            pro.StartInfo.RedirectStandardOutput = true;
            pro.StartInfo.RedirectStandardError = true;
            pro.StartInfo.CreateNoWindow = true;
            // 启动CMD
            pro.Start();
            // 运行端口检查命令
            pro.StandardInput.WriteLine("netstat -ano");
            pro.StandardInput.WriteLine("exit");
            // 获取结果
            Regex reg = new Regex(@"\s ", RegexOptions.Compiled);
            string line = null;
            while ((line = pro.StandardOutput.ReadLine()) != null)
                line = line.Trim();
                if (line.StartsWith("TCP", StringComparison.OrdinalIgnoreCase))
                    line = reg.Replace(line, ",");
                    string[] arr = line.Split('','');
                    if (arr[1].EndsWith(":"   port))
                        Console.WriteLine("8002端口的进程ID:{0}", arr[4]);
                        new Program().KillProcess(Int32.Parse(arr[4]));
        public void KillProcess(int processName) //调用方法,传参
            try
                //    //  Process[] thisproc = Process.GetProcessesByName(processName);
                Process thisproc = Process.GetProcessById(processName);
                Console.WriteLine("进程名字为:"   thisproc.ProcessName);
                if (!thisproc.CloseMainWindow()) //尝试关闭进程 释放资源
                    thisproc.Kill(); //强制关闭
                Console.WriteLine("进程 {0}关闭成功", processName);
            catch //出现异常,表明 kill 进程失败
                Console.WriteLine("结束进程{0}出错!", processName);
            finally {
                Console.ReadKey();
该文章在 2021/2/21 17:50:41 编辑过
