C#中FormBorderStyle.None时,支持改变窗体大小和拖动窗体移动的两个方法
2021年2月25日 10:28
本文热度 8864
//FormBorderStyle.None时,支持改变窗体大小
#region 支持改变窗体大小
private const int Guying_HTLEFT = 10;
private const int Guying_HTRIGHT = 11;
private const int Guying_HTTOP = 12;
private const int Guying_HTTOPLEFT = 13;
private const int Guying_HTTOPRIGHT = 14;
private const int Guying_HTBOTTOM = 15;
private const int Guying_HTBOTTOMLEFT = 0x10;
private const int Guying_HTBOTTOMRIGHT = 17;
protected override void WndProc(ref Message m)
switch (m.Msg)
case 0x0084:
base.WndProc(ref m);
Point vPoint = new Point((int)m.LParam & 0xFFFF, (int)m.LParam >> 16 & 0xFFFF);
vPoint = PointToClient(vPoint);
if (vPoint.X <= 5)
if (vPoint.Y <= 5)
m.Result = (IntPtr)Guying_HTTOPLEFT;
else if (vPoint.Y >= ClientSize.Height - 5)
m.Result = (IntPtr)Guying_HTBOTTOMLEFT;
else
m.Result = (IntPtr)Guying_HTLEFT;
else if (vPoint.X >= ClientSize.Width - 5)
if (vPoint.Y <= 5)
m.Result = (IntPtr)Guying_HTTOPRIGHT;
m.Result = (IntPtr)Guying_HTBOTTOMRIGHT;
else
m.Result = (IntPtr)Guying_HTRIGHT;
else if (vPoint.Y <= 5)
m.Result = (IntPtr)Guying_HTTOP;
m.Result = (IntPtr)Guying_HTBOTTOM;
break;
case 0x0201://鼠标左键按下的消息
m.Msg = 0x00A1;//更改消息为非客户区按下鼠标
m.LParam = IntPtr.Zero; //默认值
m.WParam = new IntPtr(2);//鼠标放在标题栏内
break;
default:
break;
#endregion
将代码复制到项目中便可移动这个窗体和改变窗体大小
===========================分割线=====================================
下面的是设置一个panel控件拖动窗体
#region panel控件移动
private System.Drawing.Point mPoint;
private void panel1_MouseMove(object sender, MouseEventArgs e)
if (e.Button == MouseButtons.Left)
Location = new System.Drawing.Point(Location.X + e.X - mPoint.X, Location.Y + e.Y - mPoint.Y);
private void panel1_MouseDown(object sender, MouseEventArgs e)
mPoint = new System.Drawing.Point(e.X, e.Y);
#endregion
该文章在 2021/2/25 10:28:48 编辑过
