[点晴永久免费OA]C#创建并设置IIS网站应用程序池
2023年1月19日 0:49 本文热度 5984
        /// <summary>
        /// 创建应用程序池 IIS 7 默认是 FrameWork 4.0  集成模式
        /// </summary>
        /// <param name="appPoolName"></param>
        /// <param name="maxProcesses">最大进程数</param>
        /// <param name="queueLength">队列长度</param>
        /// <param name="type">0为集成模式1为经理模式</param>
        public static bool createAppPool7(string appPoolName, long maxProcesses,long queueLength,string type)
            try
                ServerManager sm = new ServerManager();
                //判断是否存在应用程序池
                ApplicationPool appPool = sm.ApplicationPools[appPoolName];
                if (appPool == null)
                    sm.ApplicationPools.Add(appPoolName);
                    ApplicationPool apppool = sm.ApplicationPools[appPoolName];
                    if ("0".Equals(type))
                        apppool.ManagedPipelineMode = ManagedPipelineMode.Integrated;//托管管道为集成模式  ManagedPipelineMode.Classic为经典模式
                    else {
                        apppool.ManagedPipelineMode = ManagedPipelineMode.Classic;//托管管道为经典模式  ManagedPipelineMode.Classic为经典模式
                    apppool.ManagedRuntimeVersion = "v4.0";  //当设置错误时,会在应用程序中创建一个不存在的版本,不会报错
                    //应当检测当前电脑是否安装 FrameWork 4.0 ,并处理没有安装时该怎么办
                    //apppool.QueueLength
                    apppool.Recycling.DisallowOverlappingRotation = false;
                    apppool.Recycling.PeriodicRestart.Time = TimeSpan.fromMinutes(0);
                    apppool.Recycling.PeriodicRestart.Schedule.Add(TimeSpan.Parse("23:00:00"));
                    apppool.Recycling.PeriodicRestart.Schedule.Add(TimeSpan.Parse("06:00:00"));
                    apppool.Recycling.PeriodicRestart.Schedule.Add(TimeSpan.Parse("12:30:00"));
                    apppool.Recycling.PeriodicRestart.Schedule.Add(TimeSpan.Parse("18:00:00"));
                    apppool.Recycling.LogEventOnRecycle = RecyclingLogEventOnRecycle.Memory
                        | RecyclingLogEventOnRecycle.Requests
                        | RecyclingLogEventOnRecycle.ConfigChange
                        | RecyclingLogEventOnRecycle.IsapiUnhealthy
                        | RecyclingLogEventOnRecycle.OnDemand
                        | RecyclingLogEventOnRecycle.PrivateMemory
                        | RecyclingLogEventOnRecycle.Schedule
                        | RecyclingLogEventOnRecycle.Time;
                    apppool.Recycling.PeriodicRestart.Memory = 40960000;
                    apppool.Recycling.PeriodicRestart.PrivateMemory= 0;
                    apppool.ProcessModel.IdleTimeout = TimeSpan.fromMinutes(0);
                    apppool.ProcessModel.MaxProcesses= maxProcesses;
                    apppool.ProcessModel.ShutdownTimeLimit = TimeSpan.fromSeconds(120);//关闭时间限制设置为120秒
                    apppool.QueueLength = queueLength;
                    apppool.Cpu.Limit = 80000;
                    apppool.Cpu.Action=ProcessorAction.KillW3wp;
                    apppool.Failure.RapidFailProtection = false;
                    apppool.AutoStart = true;
                    sm.CommitChanges();
                    apppool.Recycle();
                else
                    //appPool.ManagedPipelineMode = ManagedPipelineMode.Integrated;//托管管道为集成模式  ManagedPipelineMode.Classic为经典模式
                    else
                        appPool.ManagedPipelineMode = ManagedPipelineMode.Classic;//托管管道为经典模式  ManagedPipelineMode.Classic为经典模式
                    appPool.ManagedRuntimeVersion = "v4.0";  //当设置错误时,会在应用程序中创建一个不存在的版本,不会报错
                    appPool.Recycling.DisallowOverlappingRotation = false;
                    appPool.Recycling.PeriodicRestart.Time = TimeSpan.fromMinutes(0);
                    appPool.Recycling.PeriodicRestart.Schedule.Clear();
                    appPool.Recycling.PeriodicRestart.Schedule.Add(TimeSpan.Parse("23:00:00"));
                    appPool.Recycling.PeriodicRestart.Schedule.Add(TimeSpan.Parse("06:00:00"));
                    appPool.Recycling.PeriodicRestart.Schedule.Add(TimeSpan.Parse("12:30:00"));
                    appPool.Recycling.PeriodicRestart.Schedule.Add(TimeSpan.Parse("18:00:00"));
                    appPool.Recycling.LogEventOnRecycle = RecyclingLogEventOnRecycle.Memory
                    appPool.Recycling.PeriodicRestart.Memory = 40960000;
                    appPool.Recycling.PeriodicRestart.PrivateMemory = 0;
                    appPool.ProcessModel.IdleTimeout = TimeSpan.fromMinutes(0);
                    appPool.ProcessModel.MaxProcesses = maxProcesses;
                    appPool.ProcessModel.ShutdownTimeLimit = TimeSpan.fromSeconds(120);//关闭时间限制设置为120秒
                    appPool.QueueLength = queueLength;
                    appPool.Cpu.Limit = 80000;
                    appPool.Cpu.Action = ProcessorAction.KillW3wp;
                    appPool.Failure.RapidFailProtection = false;
                    appPool.AutoStart = true;
                    sm.CommitChanges();
                    appPool.Recycle();
            catch
                return false;
            return true;
该文章在 2023/1/19 0:49:15 编辑过
