【JavaScript】spreadjs使用
2023年5月25日 10:22 本文热度 5606
初始化表单API
1.  const spreadNS = GC.Spread.Sheets;
2.  const SHEETS = new spreadNS.Workbook(this.refs['overseas']);
3.  // set sheet count
4.  // SHEETS.setSheetCount(1);
5.
6.  const sheet = SHEETS.sheets[0];
设置默认属性
1.  const defaultStyle = new GC.Spread.Sheets.Style();
2.  // 设置默认背景色
3.  // @method1 defaultStyle.backColor = "LemonChiffon";
4.  // @method2 SHEETS.options.backColor = "#ccc";
5.  //defaultStyle.foreColor = "Red";
6.  //defaultStyle.formatter = "0.00";
7.  defaultStyle.font   = "bold normal 9px normal"
8.  defaultStyle.hAlign = GC.Spread.Sheets.HorizontalAlign.center;
9.  defaultStyle.vAlign = GC.Spread.Sheets.VerticalAlign.center;
10.//defaultStyle.borderLeft = new GC.Spread.Sheets.LineBorder("Green",GC.Spread.Sheets.LineStyle.medium);
11.//defaultStyle.borderTop = new GC.Spread.Sheets.LineBorder("Green",GC.Spread.Sheets.LineStyle.medium);
12.//defaultStyle.borderRight = new GC.Spread.Sheets.LineBorder("Green",GC.Spread.Sheets.LineStyle.medium);
13.//defaultStyle.borderBottom = new GC.Spread.Sheets.LineBorder("Green",GC.Spread.Sheets.LineStyle.medium);
14.sheet.setDefaultStyle(defaultStyle, spreadNS.SheetArea.viewport);
表格的四个部分
1.  spreadNS.SheetArea.viewport
2.
3.  // spreadNS.SheetArea include the following parts
4.  // colHeader: 1 ,
5.  //    corner: 0
6.  // rowHeader: 2
7.  //  viewport: 3
8.
9.  // 改变表头的背景 Set the backcolor of second row header.
10.sheet.getCell(1, 0, GC.Spread.Sheets.SheetArea.rowHeader).backColor("Yellow");
其他配置
1.  // 表格下边的tab的颜色
2.  sheet.options.sheetTabColor = "red";
3.
4.  // 表格只读
5.  sheet.options.isProtected = true
6.
7.  // 允许cell内容移除
8.  activeSheet.options.allowCellOverflow = true;
9.
10.// 第一列不可见
11.sheet.setColumnVisible(0, false)
12.
13.// 添加tips
14.sheet.comments.add(4, 4, "不要修改!");
15.
16.// 禁止用户编辑公式
17.spread.options.allowUserEditFormula = false;
18.
19.// 不显示格子的边
20.sheet.options.gridline = {
21.    color:"red",
22.    showVerticalGridline: true,
23.    showHorizontalGridline: false
24.};
25.
26.// 不显示表头
27.activeSheet.options.colHeaderVisible = false;
28.activeSheet.options.rowHeaderVisible = false;
减少重绘
1.  spread.reset() // 清空数据
2.  spread.suspendPaint();  //suspendPaint 暂停重绘  先这样 很多操作之后 resumePaint
3.  spread.addSheet(0);
4.  spread.fromJSON(json);  // json data
5.  spread.resumePaint();   // 调用resumePaint 重新激活Spread重绘
excel 运算符
1.  引用运算符 含义(示例)
2.  :(冒号) 区域运算符,产生对包括在两个引用之间的所有单元格的引用 (B5:B15)
3.  ,(逗号) 联合运算符,将多个引用合并为一个引用 (SUM(B5:B15,D5:D15))
4.  (空格) 交叉运算符产生对两个引用共有的单元格的引用。(B7:D7 C6:C8)
设置单元格属性
1.
2.  sheet.getCell(2, 1).
3.  text("huahua").             // 设置文字
4.  backColor("rgba(1,1,1,.3)") //设置背景色
公式
1.  // 随机数
2.   sheet.setFormula(1, 1, "RandBetween(45,85)");
3.
4.  // 求和
5.  sheet.setFormula(1, 1, "SUM(A1,B1)"); //A1和B1之和
6.  sheet.setFormula(1, 1, "SUM(A1:H1)"); //A1到H1之和
7.
8.  // 条件
9.  sheet.setFormula(4, 1, "IF(A1>10, A1*2, A1*3)");
开启R1C1 引用
1.  // open r1c1 reference
2.  SHEETS.options.referenceStyle = 1;
基本操作
1.  // 添加行/列
2.  sheet.addRows(1, 1);    sheet.addColumns(1, 1);
3.
4.  // 设置背景图片
5.  activeSheet.getCell(1, 1).backgroundImage("Image file path name");
设置row和column的背景色
1.  /**
2.  * @name set the bgColor of column
3.  *
4.  * @type1
5.  * sheet.getRange(-1, 1, -1, 1).backColor("lightYellow").width(330);
6.  *
7.  * @name set the bgColor of row
8.  *
9.  * @type1
10.* sheet.getRange(0, -1, 1, -1).backColor("lightYellow").height(44)
11.*
12.* @type2
13.* const rowStyle1 = new spreadNS.Style();
14.* rowStyle1.backColor = "#bdcde3";
15.* sheet.setStyle(0, -1, rowStyle1, spreadNS.SheetArea.viewport);
16.*/
events
1.  // 获取点击的cell和所在的sheet
2.  SHEETS.bind(spreadNS.Events.EnterCell, function (event, data) {
3.      console.log(data.col)
4.      console.log(data.row)
5.      console.log(data)
6.      var activeSheet = data.sheet;
7.      activeSheet.startEdit(true);
8.  });
9.
10.// 离开cell事件
11.sheet.bind(GC.Spread.Sheets.Events.LeaveCell, function (event, infos) {
12.    //Reset the backcolor of cell before moving
13.    infos.sheet.getCell(infos.row, infos.col).backColor(undefined);
14.});
15.
16.//粘贴事件
17.spread.bind(GC.Spread.Sheets.Events.ClipboardPasted, function (sender, args) {
18.    if (sheet.getCell(args.cellRange.row, args.cellRange.col).locked()) {
19.       return;
20.    }
21.    console.log("ClipboardPasted");
22.});
23.
24.//值改变事件
25.spread.bind(GC.Spread.Sheets.Events.ValueChanged, function (sender, args) {
26....
27.});
28.
29.//按钮点击事件
30.spread.bind(GC.Spread.Sheets.Events.ButtonClicked, function(e, args) {
31....
32.});
33.
34.//单元格点击事件
35.spread.bind(GC.Spread.Sheets.Events.CellClick, function(sender, args) {
36....
37.});
该文章在 2023/5/25 10:22:56 编辑过
