推荐一个C#开发的、跨平台的解压缩的开源项,值得收藏
2023年8月16日 9:34 本文热度 5547
解压缩对于我们日常工作太经常用到了,毕竟它有诸多好处,比如节省空间、方便管理传输、保密作用等等。
而对于我们开发人员来说,项目开发也是经常需要用到,今天就给大家推荐用一个可以用于压缩、解压、解密,并支持多种压缩类型和格式的开源项目。
项目简介
这是一个纯C#压缩库,用于.NET Standard 2.0、2.1、.NET Core 3.1和.NET 5.0,支持格式有zip/tar/bzip2/gzip/lzip,功能实现有解压缩rar, 解压缩7zip, 解压缩zip, 解压缩tar解压缩bzip2, 解压缩gzip, 解压缩lzip。
项目结构
使用方法
压缩核心代码
protected void Write(CompressionType compressionType, string archive, string archiveToVerifyAgainst, Encoding encoding = null)
using (Stream stream = File.OpenWrite(Path.Combine(SCRATCH2_FILES_PATH, archive)))
      WriterOptions writerOptions = new WriterOptions(compressionType)
         LeaveStreamOpen = true,
      writerOptions.ArchiveEncoding.Default = encoding ?? Encoding.Default;
using (var writer = WriterFactory.Open(stream, type, writerOptions))
         writer.WriteAll(ORIGINAL_FILES_PATH, "*", SearchOption.AllDirectories);
   CompareArchivesByPath(Path.Combine(SCRATCH2_FILES_PATH, archive),
      Path.Combine(TEST_ARCHIVES_PATH, archiveToVerifyAgainst));
using (Stream stream = File.OpenRead(Path.Combine(SCRATCH2_FILES_PATH, archive)))
      ReaderOptions readerOptions = new ReaderOptions();
      readerOptions.ArchiveEncoding.Default = encoding ?? Encoding.Default;
using (var reader = ReaderFactory.Open(NonDisposingStream.create(stream), readerOptions))
         reader.WriteAllToDirectory(SCRATCH_FILES_PATH, new ExtractionOptions()
            ExtractFullPath = true
   VerifyFiles();
解压核心代码
public abstract class ReaderTests : TestBase
         protected void Read(string testArchive, CompressionType expectedCompression, ReaderOptions options = null)
                   testArchive = Path.Combine(TEST_ARCHIVES_PATH, testArchive);
                   options = options ?? new ReaderOptions();
                   options.LeaveStreamOpen = true;
                   ReadImpl(testArchive, expectedCompression, options);
                   options.LeaveStreamOpen = false;
                   VerifyFiles();
         private void ReadImpl(string testArchive, CompressionType expectedCompression, ReaderOptions options)
         using (var file = File.OpenRead(testArchive))
         using (var protectedStream = NonDisposingStream.create(new ForwardOnlyStream(file), throwOnDispose: true))
         using (var testStream = new TestStream(protectedStream))
         using (var reader = ReaderFactory.Open(testStream, options))
                                                        UseReader(reader, expectedCompression);
                                                        protectedStream.ThrowOnDispose = false;
                                                        Assert.False(testStream.IsDisposed, "{nameof(testStream)} prematurely closed");
         // Boolean XOR -- If the stream should be left open (true), then the stream should not be diposed (false)
         // and if the stream should be closed (false), then the stream should be disposed (true)
         var message = $"{nameof(options.LeaveStreamOpen)} is set to '{options.LeaveStreamOpen}', so {nameof(testStream.IsDisposed)} should be set to '{!testStream.IsDisposed}', but is set to {testStream.IsDisposed}";
                                               Assert.True(options.LeaveStreamOpen != testStream.IsDisposed, message);
         public void UseReader(IReader reader, CompressionType expectedCompression)
         while (reader.MoveToNextEntry())
         if (!reader.Entry.IsDirectory)
                                     Assert.Equal(expectedCompression, reader.Entry.CompressionType);
                                     reader.WriteEntryToDirectory(SCRATCH_FILES_PATH, new ExtractionOptions()
                                               ExtractFullPath = true,
                                               Overwrite = true
zip压缩用法
Write(CompressionType.None, "Zip.none.noEmptyDirs.zip", "Zip.none.noEmptyDirs.zip", Encoding.UTF8);
zip解压用法
Read("Zip.zipx", CompressionType.LZMA);
项目还未支持
  • RAR 5 解密
  • 7Zip 写入
  • Zip64  解压缩
  • 多卷Zip支持
项目地址:https://github.com/adamhathcock/sharpcompress
- End -
该文章在 2023/8/16 9:39:40 编辑过
