如何将SQL语句进行格式化处理?
2023年9月21日 16:27 本文热度 5550
先看效果:
直接上代码:
public Form1()
InitializeComponent();
Init();
#region 初始化配置
ISqlTokenizer _tokenizer;
ISqlTokenParser _parser;
ISqlTreeFormatter _formatter;
public void Init()
    chk_default.Checked = true;
    _tokenizer = new BaiSqlFormatLib.Tokenizers.TSqlStandardTokenizer();
    _parser = new BaiSqlFormatLib.Parsers.TSqlStandardParser();
#endregion
#region 格式化
private void textBox1_KeyDown(object sender, KeyEventArgs e)
    if (e.KeyData == Keys.F6)
        txt_format.DocumentText = Format(txt_sql.Text);
private string Format(string inputSql)
    SetFormatter();
    var tokenizedSql = _tokenizer.TokenizeSQL(inputSql, inputSql.Length);
    var parsedSql = _parser.ParseSQL(tokenizedSql);
    string subSqlHtml = _formatter.FormatSQLTree(parsedSql);
    return subSqlHtml;
/// <summary>
/// 设置格式化属性
/// </summary>
private void SetFormatter()
ISqlTreeFormatter innerFormatter = new BaiSqlFormatLib.Formatters.TSqlStandardFormatter(new BaiSqlFormatLib.Formatters.TsqlStandardFormatterOptions{
        IndentString = "\\s\\s\\s\\s", //缩进内容
        SpacesPerTab = 4,
        MaxLineWidth = Convert.ToInt32(txt_maxWidth.Text), //单行字符串最大长度
        ExpandCommaLists = !chk_columnNotNewline.Checked,  //false 字段换行
        KeywordAlign = chk_keywordAlign.Checked,     //字段对齐
        TrailingCommas = true,   //true 逗号在字段之后
        SpaceAfterExpandedComma = true,  //true 逗号后追加空格
        ExpandBooleanExpressions = chk_conditionNewline.Checked,  //true 条件换行
        ExpandCaseStatements = chk_expandCase.Checked,      //true case when换行
        ExpandBetweenConditions = chk_expandBetween.Checked,  //true between 换行
        ExpandInLists = chk_expandIn.Checked,   //true in 内容换行
        BreakJoinOnSections = chk_expandOn.Checked, //true join on中on 条件换行
        UppercaseKeywords = chk_uppercaseKeywords.Checked, //true 关键字大写
        AllUpper = chk_allUpper.Checked, //true 全部大写
        HTMLColoring = chk_coloring.Checked, //true HTML颜色标记 默认为true
        KeywordStandardization = true,//true 关键字标准化
        NewStatementLineBreaks = 2, //新语句换行数
        NewClauseLineBreaks = 1,//遇到关键字 换行数
        AllIndent = chk_allIndent.Checked, //整体缩进一个IndentString
        AsAlign = chk_asAlign.Checked, //true as对齐
        KeywordLengthOfAs = Convert.ToInt32(txt_asMaxWidth.Text)//as字段的最大长度
    _formatter = new BaiSqlFormatLib.Formatters.HtmlPageWrapper(innerFormatter);
#region 页面配置
private void chk_default_CheckedChanged(object sender, EventArgs e)
    if (chk_default.Checked)
        chk_custom.CheckState = CheckState.Unchecked;
        txt_maxWidth.Text =
"170";
        chk_columnNotNewline.CheckState = CheckState.Unchecked;
        chk_keywordAlign.CheckState = CheckState.Checked;
        chk_conditionNewline.CheckState = CheckState.Checked;
        chk_expandCase.CheckState = CheckState.Checked;
        chk_expandBetween.CheckState = CheckState.Unchecked;
        chk_expandIn.CheckState = CheckState.Unchecked;
        chk_expandOn.CheckState = CheckState.Checked;
        chk_uppercaseKeywords.CheckState = CheckState.Unchecked;
        chk_allUpper.CheckState = CheckState.Unchecked;
        chk_coloring.CheckState = CheckState.Checked;
        chk_allIndent.CheckState = CheckState.Checked;
        chk_asAlign.CheckState = CheckState.Checked;
        txt_asMaxWidth.Text = "35";
        chk_addSemicolon.CheckState = CheckState.Checked;
        txt_maxWidth.Enabled =
false;
        chk_columnNotNewline.Enabled = false;
        chk_keywordAlign.Enabled = false;
        chk_conditionNewline.Enabled = false;
        chk_expandCase.Enabled = false;
        chk_expandBetween.Enabled = false;
        chk_expandIn.Enabled = false;
        chk_expandOn.Enabled = false;
        chk_uppercaseKeywords.Enabled = false;
        chk_allUpper.Enabled = false;
        chk_coloring.Enabled = false;
        chk_allIndent.Enabled = false;
        chk_asAlign.Enabled = false;
        txt_asMaxWidth.Enabled = false;
        chk_addSemicolon.Enabled = false;
    else
        chk_custom.CheckState = CheckState.Checked;
private void chk_custom_CheckedChanged(object sender, EventArgs e)
    if (chk_custom.Checked)
        chk_default.CheckState = CheckState.Unchecked;
        chk_columnNotNewline.Enabled = true;
        chk_keywordAlign.Enabled = true;
        chk_conditionNewline.Enabled = true;
        chk_expandCase.Enabled = true;
        chk_expandBetween.Enabled = true;
        chk_expandIn.Enabled = true;
        chk_expandOn.Enabled = true;
        chk_uppercaseKeywords.Enabled = true;
        chk_allUpper.Enabled = true;
        chk_coloring.Enabled = true;
        chk_allIndent.Enabled = true;
        chk_asAlign.Enabled = true;
        chk_addSemicolon.Enabled = true;
        txt_maxWidth.Enabled = true;
        txt_asMaxWidth.Enabled = true;
    else
        chk_default.CheckState = CheckState.Checked;
#endregion
感兴趣的小伙伴可以自己研究研究。
该文章在 2023/9/21 16:27:57 编辑过
