C# 实现断点续传功能
2024年3月13日 0:29 本文热度 5011
1.    using System;
2.    using System.Collections.Generic;
3.    using System.IO;
4.    using System.Linq;
5.    using System.Net;
6.    using System.Text;
7.    using System.Text.RegularExpressions;
8.    using System.Threading.Tasks;
9.
10. namespace Utils
11. {
12. public class HttpUtil
13. {
14. public static bool isUrl(string url)
15. {
16. // 正则表达式
17. string pattern = @"^(https?://)?([\w-]+\.)+[\w-]+(/[\w-./?%&=]*)?";
18. // 创建正则表达式对象
19. Regex regex = new Regex(pattern, RegexOptions.IgnoreCase);
20. // 判断字符串是否匹配正则表达式
21. return regex.IsMatch(url);
22. }
23.
24. public static string DoGet(string url)
25. {
26. string result = string.Empty;
27. try
28. {
29. HttpWebRequest myRequest = (HttpWebRequest)WebRequest.Create(url);
30. HttpWebResponse myResponse = (HttpWebResponse)myRequest.GetResponse();
31. StreamReader reader = new StreamReader(myResponse.GetResponseStream(), Encoding.UTF8);
32. result = reader.ReadToEnd();//利用StreamReader就可以从响应内容从头读到尾
33. reader.Close();
34. myResponse.Close();
35. }
36. catch
37. {
38. }
39. return result;
40. }
41.
42. /// <summary>
43. /// 获取一个网络文件的大小
44. /// </summary>
45. /// <param name="url"></param>
46. /// <returns></returns>
47. public static async Task<long> GetFileSize(string url)
48. {
49. long fileSize = 0;
50. await Task.Run(() =>
51. {
52. try
53. {
54. WebRequest request = WebRequest.Create(url);
55. request.Method = "HEAD";
56. using (WebResponse response = request.GetResponse())
57. {
58. if (long.TryParse(response.Headers.Get("Content-Length"), out fileSize))
59. {
60. return fileSize;
61. }
62. }
63. }
64. catch (Exception)
65. {
66. }
67. return fileSize;
68. });
69. return fileSize;
70. }
71.
72. /// <summary>
73. /// 断点续传功能
74. /// </summary>
75. /// <param name="fileUrl">下载链接</param>
76. /// <param name="saveFilePath">文件保存路径</param>
77. /// <param name="progress">进度百分比</param>
78. /// <returns></returns>
79. public static async Task<double> DownloadFileWithResume(string fileUrl, string saveFilePath, Action<double> progress = null)
80. {
81. long fileSize = 0;
82. if (File.Exists(saveFilePath))
83. {
84. var fileInfo = new FileInfo(saveFilePath);
85. fileSize = fileInfo.Length;
86. }
87.
88. HttpWebRequest request = (HttpWebRequest)WebRequest.Create(fileUrl);
89. request.Method = "GET";
90.
91. if (fileSize > 0)
92. {
93. //对比已存在文件与网络文件实际大小,如果相等,则为已下载完成的
94. long realitySize = await GetFileSize(fileUrl);
95. if (realitySize == fileSize)
96. {
97. progress?.Invoke(100);
98. return 100;
99. }
100.           request.AddRange(fileSize);
101.           }
102.
103.           HttpWebResponse response = (HttpWebResponse)await request.GetResponseAsync();
104.           long contentLength = response.ContentLength + fileSize;
105.           double percentComplete = 0;
106.           using (FileStream fileStream = new FileStream(saveFilePath, FileMode.Append))
107.           {
108.           byte[] buffer = new byte[4096];
109.           using (Stream responseStream = response.GetResponseStream())
110.           {
111.           int bytesRead = 0;
112.           long bytesReceived = fileSize;
113.           while ((bytesRead = await responseStream.ReadAsync(buffer, 0, buffer.Length)) > 0)
114.           {
115.           await fileStream.WriteAsync(buffer, 0, bytesRead);
116.           bytesReceived += bytesRead;
117.           percentComplete = (double)bytesReceived / (double)contentLength;
118.           progress?.Invoke(percentComplete);
119.           //Console.WriteLine("Download progress: {0:P}", percentComplete);
120.           }
121.           }
122.           }
123.           return percentComplete;
124.           }
125.
126.           }
127.           }
该文章在 2024/3/13 0:31:15 编辑过
