我需要打印一个标签,上面有文字、图片、线条、一维码、二维码等内容打印前需要预览,用C#如何将内容加载到panel或PrintPreviewDialog控件中,实现预览效果
2025年6月27日 16:6 本文热度 5528
在C#中实现标签打印预览,可以通过自定义绘制内容到Panel控件或直接使用PrintDocument实现。以下是两种推荐方案:
方案1:使用Panel控件模拟预览(适合简单需求)
// 添加Panel控件到窗体 (panelPreview)
private void GeneratePreview()
    panelPreview.Paint += (sender, e) =>
        Graphics g = e.Graphics;
        g.Clear(Color.White);
        g.SmoothingMode = SmoothingMode.AntiAlias;
        // 1. 绘制文字
        using (Font font = new Font("微软雅黑", 10))
            g.DrawString("产品标签", font, Brushes.Black, new PointF(20, 20));
        // 2. 绘制图片
        Image logo = Image.FromFile("logo.png");
        g.DrawImage(logo, new Rectangle(20, 50, 100, 50));
        // 3. 绘制线条
        using (Pen pen = new Pen(Color.Black, 1))
            g.DrawLine(pen, 20, 110, 200, 110);
        // 4. 绘制一维码 (需安装BarcodeLib)
        Barcode barcode = new Barcode();
        Image barcodeImg = barcode.Encode(BarcodeLib.TYPE.CODE128, "123456");
        g.DrawImage(barcodeImg, 20, 130);
        // 5. 绘制二维码 (需安装ZXing.Net)
        var writer = new BarcodeWriterPixelData
            Format = BarcodeFormat.QR_CODE,
            Options = new EncodingOptions { Height = 100, Width = 100 }
        var pixelData = writer.Write("https://example.com");
        using (Bitmap qrImg = new Bitmap(pixelData.Width, pixelData.Height, PixelFormat.Format32bppRgb))
            BitmapData bmData = qrImg.LockBits(new Rectangle(0, 0, qrImg.Width, qrImg.Height), ImageLockMode.WriteOnly, qrImg.PixelFormat);
            Marshal.Copy(pixelData.Pixels, 0, bmData.Scan0, pixelData.Pixels.Length);
            qrImg.UnlockBits(bmData);
            g.DrawImage(qrImg, 150, 130);
    panelPreview.Invalidate(); // 触发重绘
// 打印按钮事件
private void btnPrint_Click(object sender, EventArgs e)
    PrintDocument pd = new PrintDocument();
    pd.PrintPage += (s, args) =>
        // 创建与打印机分辨率匹配的Bitmap
        Bitmap bmp = new Bitmap(panelPreview.Width, panelPreview.Height);
        panelPreview.DrawToBitmap(bmp, panelPreview.ClientRectangle);
        args.Graphics.DrawImage(bmp, args.MarginBounds);
    PrintPreviewDialog preview = new PrintPreviewDialog();
    preview.Document = pd;
    preview.ShowDialog();
方案2:直接使用PrintDocument(推荐专业方案)
private void PrintWithPreview()
    pd.DefaultPageSettings.PaperSize = new PaperSize("Custom", 300, 200); // 标签尺寸(1/10英寸)
    pd.PrintPage += (sender, e) =>
        g.PageUnit = GraphicsUnit.Millimeter; // 使用毫米单位
        // 绘制元素(单位毫米)
        g.DrawString("产品标签", new Font("Arial", 8), Brushes.Black, 10, 5);
        // 绘制图片(自动缩放)
        g.DrawImage(logo, new RectangleF(10, 15, 30, 15));
        // 绘制线条
        g.DrawLine(new Pen(Color.Black, 0.2f), 10, 35, 80, 35);
        // 绘制条码(使用内存绘制)
        using (Bitmap barcode = GenerateBarcode("123456"))
            g.DrawImage(barcode, 10, 40, 50, 15);
    // 显示预览
// 生成条码辅助方法
private Bitmap GenerateBarcode(string text)
    return barcode.Encode(BarcodeLib.TYPE.CODE128, text);
推荐方案比较
方案优点缺点适用场景
Panel预览开发简单,所见即所得分辨率低,打印质量受限简单标签、快速原型
PrintDocument打印质量高,支持专业打印控制需要双重绘制逻辑商业级标签打印
专业建议
1、条码生成库
  • 一维码:安装NuGet包 BarcodeLib
  • 二维码:安装 ZXing.Net (支持QR Code/Datamatrix等)
Install-Package BarcodeLib
Install-Package ZXing.Net
2、精确控制打印尺寸
// 设置精确的标签尺寸(毫米转1/100英寸)
int widthInHundredths = (int)(50 * 100 / 25.4); // 50mm
int heightInHundredths = (int)(30 * 100 / 25.4); // 30mm
pd.DefaultPageSettings.PaperSize = new PaperSize("Custom", widthInHundredths, heightInHundredths);
3、使用专业标签设计器
对于复杂标签需求,推荐集成第三方控件:
  • ​Bartender Automation (商业级)
  • Labelary Web Service (在线服务)
  • Telerik Reporting (报表控件)
4、分辨率处理技巧
// 提高打印质量
e.Graphics.InterpolationMode = InterpolationMode.HighQualityBicubic;
e.Graphics.PixelOffsetMode = PixelOffsetMode.HighQuality;
重要提示:实际打印前务必测试不同DPI的打印机,建议使用e.Graphics.DpiX和e.Graphics.DpiY获取打印机实际分辨率进行自适应布局。
完整实现步骤:
  1. 创建打印内容模型类
  2. 设计预览面板/打印文档的绘制逻辑
  3. 添加打印机设置界面(选择纸张、尺寸等)
  4. 实现打印预览和打印功能
  5. 添加条码生成异常处理
通过以上方法,您可以实现专业的标签打印预览系统,满足文字、图片、线条、条码等混合内容的打印需求。
该文章在 2025/6/27 17:03:51 编辑过
