nginx lua防火墙防SQL注入配置
2025年6月28日 22:17 本文热度 4675
一、防火墙配置
参考 nginx配置lua防火墙
二、准备演示环境
1. 前端演示页面
<html>
<head>
    <title>登陆</title>
    <meta charset="utf-8">
</head>
<body>
    <div>
        用户名:<input type="text" name="user" id="txtUser"><br>
        密码:<input type="password" name="pwd" id="txtPassword"><br>
        <input type="button" onclick="login('login')" value="登陆"> <br>
        <div id="divMsg"></div>
        <script>
            function login(action) {
                var httpRequest = new XMLHttpRequest()
                httpRequest.onreadystatechange = function () {
                    if (httpRequest.readyState == 4) {
                        document.getElementById("divMsg").innerText = httpRequest.responseText
                httpRequest.open('POST', `/api/${action}`, true)
                httpRequest.setRequestHeader(
                    'Content-type',
                    'application/x-www-form-urlencoded'
                var user = document.getElementById("txtUser").value
                var pwd = document.getElementById("txtPassword").value
                var str = `username=${user}&password=${pwd}`
                httpRequest.send(str)
        </script>
    </div>
</body>
</html>
2. 服务端演示代码,模拟SQL注入
@Autowired
JdbcTemplate jdbcTemplate;
 * 拼sql查询
 * @param user
 * @return
@PostMapping("/login")
public String login(User user) {
    String sql = "select * from sys_user where user_name = '" + user.getUsername() + "' and pass_word = '" + user.getPassword() + "'";
    System.out.println("SQL:");
    System.out.println(sql);
    List<Map<String, Object>> maps = jdbcTemplate.queryForList(sql);
    System.out.println(maps.size());
    if (maps.size() > 0) {
        return"login success";
    } else {
        return"login fail";
3. nginx代理设置
location /api/ {
    proxy_set_header Host $http_host;
    proxy_set_header X-Real-IP $remote_addr;
    proxy_set_header REMOTE-HOST $remote_addr;
    proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
    proxy_pass http://192.168.1.18:8093/;
4. 配置拦截参数(lua防火墙通过检测post表单中的关键字实现拦截)。
# 设置SQL注入的关键参数
echo "'\s+or\s+" >> /usr/local/nginx/conf/ngx_lua_waf/wafconf/post
# 重新加载,使配置生效
/usr/local/nginx/sbin/nginx -s reload
三、效果演示
1. 正常登陆
2. 注入成功,在配置post拦截参数以前的效果
3. 注入被拦截,在配置post拦截参数以后的效果
该文章在 2025/7/1 23:48:34 编辑过
