[点晴永久免费OA]远程桌面 P2P - 便携式,无需配置或安装,无需中转服务器
2025年12月18日 23:14
本文热度 4936
P2P 远程桌面
基于远程桌面 P2P - 便携式,无需配置或安装。支持直接点对点连接,不需要任何中转服务器,因此具有较高的连接稳定性和速度
项目地址
https://github.com/miroslavpejic85/p2p
#Windows #开源
附件:p2p-portable.zip
- Copy the
My Lan or Wan IP and communicate it to other peer and vice versa.
- The 2 peers have now the 2 endpoint to connect to, so press on both
Connect. - The 2 peers now are able to
sent messages or take the Remote Desktop Control between them.
It's use UDT protocol and thanks to rendezvous connection, it should be able to bypass most firewall rules, like a small concept of TeamViewer at 0 cost!
The app doesn't have a digital signature being an open source project, it may be detected as a false positive by AVs. When you compile it from the source code, just add the project in the exception. Thank you for understanding.
该文章在 2025/12/19 10:21:38 编辑过
