asp 条形码打印问题
2012年9月25日 0:39 本文热度 9172
以下是asp自动生成条码,但是无法打印,打印就显示空白,网上所说的设置 工具-internet选项-高级-打印背景颜色和图像,都设置了,结果还是不行,有哪位做过类似功能,如果能生成一个图片就肯定能打印了!
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=gb2312">
<meta name="Keywords" content="51windows.Net">
<META NAME="Author" CONTENT="haiwa">
<title>Asp生成条形码</title>
<style>
* {font:menu}
</style>
</head>
<body>
'条形码生成程序
function haiwaocde(zfstr)
 zf = zfstr
 zf = replace(zf,"0","_|_|__||_||_|")
 zf = replace(zf,"1","_||_|__|_|_||")
 zf = replace(zf,"2","_|_||__|_|_||")
 zf = replace(zf,"3","_||_||__|_|_|")
 zf = replace(zf,"4","_|_|__||_|_||")
 zf = replace(zf,"5","_||_|__||_|_|")
 zf = replace(zf,"7","_|_|__|_||_||")
 zf = replace(zf,"6","_|_||__||_|_|")
 zf = replace(zf,"8","_||_|__|_||_|")
 zf = replace(zf,"9","_|_||__|_||_|")
 zf = replace(zf,"a","_||_|_|__|_||")
 zf = replace(zf,"b","_|_||_|__|_||")
 zf = replace(zf,"c","_||_||_|__|_|")
 zf = replace(zf,"d","_|_|_||__|_||")
 zf = replace(zf,"e","_||_|_||__|_|")
 zf = replace(zf,"f","_|_||_||__|_|")
 zf = replace(zf,"g","_|_|_|__||_||")
 zf = replace(zf,"h","_||_|_|__||_|")
 zf = replace(zf,"i","_|_||_|__||_|")
 zf = replace(zf,"j","_|_|_||__||_|")
 zf = replace(zf,"k","_||_|_|_|__||")
 zf = replace(zf,"l","_|_||_|_|__||")
 zf = replace(zf,"m","_||_||_|_|__|")
 zf = replace(zf,"n","_|_|_||_|__||")
 zf = replace(zf,"o","_||_|_||_|__|")
 zf = replace(zf,"p","_|_||_||_|__|")
 zf = replace(zf,"r","_||_|_|_||__|")
 zf = replace(zf,"q","_|_|_|_||__||")
 zf = replace(zf,"s","_|_||_|_||__|")
 zf = replace(zf,"t","_|_|_||_||__|")
 zf = replace(zf,"u","_||__|_|_|_||")
 zf = replace(zf,"v","_|__||_|_|_||")
 zf = replace(zf,"w","_||__||_|_|_|")
 zf = replace(zf,"x","_|__|_||_|_||")
 zf = replace(zf,"y","_||__|_||_|_|")
 zf = replace(zf,"z","_|__||_||_|_|")
 zf = replace(zf,"-","_|__|_|_||_||")
 zf = replace(zf,"*","_|__|_||_||_|")
 zf = replace(zf,"/","_|__|__|_|__|")
 zf = replace(zf,"%","_|_|__|__|__|")
 zf = replace(zf,"+","_|__|_|__|__|")
 zf = replace(zf,".","_||__|_|_||_|")
 haiwaocde = zf
end function
code_H = 52
code_W = 2
function dragcode(ccode)
 c = ccode
 c = replace(c,"_","<span style='height:"&code_H&";width:"&code_w&";background:#FFFFFF'></span>")
 c = replace(c,"|","<span style='height:"&code_H&";width:"&code_w&";background:#000000'></span>")
 dragcode = c
end function
function dragtext(ccode)
 c = ccode
 dragtext = ""
 for i=1 to len(c)
 dragtext = dragtext&"<span style='width:26;text-align:center'>"&mid(c,i,1)&"</span>"
 next
 dragtext = dragtext
end function
Function CheckExp(patrn,str)
Set regEx=New RegExp
regEx.Pattern=patrn
regEx.IgnoreCase=true
regEx.Global=True
CheckExp = regEx.test(str)
End Function
code = request("c")
if code = "" then
 code = "8888888888"
else
 if Checkexp("^[abcdefghijklmnopqrstuvwxyz1234567890\+\-\*\/\%\$\.]*$",code) then
  code = code
 else
  code = "8888888888"
  errstr = "<br><center style='color:red;'>含有非法字符 </center>"
 end if
end if
ocode = code
code = lcase(code)
<center><form name="form1" method="post">合法字符:ABCDEFGHIJKLMNOPQRSTUVWXYZ 1234567890 + - * / % $ .<br><br><input name="c" type="text" value="<%=request("c")%>" size="25" maxlength="15"> <input type="submit" name="Submit" value="提交"></form><center>
<div align="center">
  <center>
  <table border="0" cellpadding="0" cellspacing="0" height="79" >
  <tr>
  <td height="61" align="center"><%=dragcode(haiwaocde(code))%></td>
  </tr>
  <tr>
  <td height="18" align="center" ><%=(ocode)%></td>
  </tr>
  </table>
  </center>
</div>
<%=errstr%>
</body>
</html>
该文章在 2012/9/25 0:39:08 编辑过
全部评论1
2012年9月25日 0:39
barcode字体。 http://download.csdn.net/source/1607764 http://download.csdn.net/source/711623
