【JavaScript】微信小程序base64编码解码以及utf-8解码
2026年8月17日 17:51 本文热度 3039
function base64_encode (str) { // 编码,配合encodeURIComponent使用
    var c1, c2, c3;
    var base64EncodeChars = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/=";
    var i = 0, len = str.length, strin = '';
    while (i < len) {
        c1 = str.charCodeAt(i++) & 0xff;
        if (i == len) {
            strin += base64EncodeChars.charAt(c1 >> 2);
            strin += base64EncodeChars.charAt((c1 & 0x3) << 4);
            strin += "==";
            break;
        c2 = str.charCodeAt(i++);
        if (i == len) {
            strin += base64EncodeChars.charAt(((c1 & 0x3) << 4) | ((c2 & 0xF0) >> 4));
            strin += base64EncodeChars.charAt((c2 & 0xF) << 2);
            strin += "=";
            break;
        c3 = str.charCodeAt(i++);
        strin += base64EncodeChars.charAt(((c2 & 0xF) << 2) | ((c3 & 0xC0) >> 6));
        strin += base64EncodeChars.charAt(c3 & 0x3F)
    return strin
function base64_decode (input) { // 解码,配合decodeURIComponent使用
    var output = "";
    var chr1, chr2, chr3;
    var enc1, enc2, enc3, enc4;
    var i = 0;
    input = input.replace(/[^A-Za-z0-9\+\/\=]/g, "");
    while (i < input.length) {
        enc1 = base64EncodeChars.indexOf(input.charAt(i++));
        enc2 = base64EncodeChars.indexOf(input.charAt(i++));
        enc3 = base64EncodeChars.indexOf(input.charAt(i++));
        enc4 = base64EncodeChars.indexOf(input.charAt(i++));
        chr1 = (enc1 << 2) | (enc2 >> 4);
        chr2 = ((enc2 & 15) << 4) | (enc3 >> 2);
        chr3 = ((enc3 & 3) << 6) | enc4;
        output = output + String.fromCharCode(chr1);
        if (enc3 != 64) {
            output = output + String.fromCharCode(chr2);
        if (enc4 != 64) {
            output = output + String.fromCharCode(chr3);
    return utf8_decode(output);
function utf8_decode (utftext) { // utf-8解码
    var string = '';
    let i = 0;
    let c = 0;
    let c1 = 0;
    let c2 = 0;
    while (i < utftext.length) {
        c = utftext.charCodeAt(i);
        if (c < 128) {
            string += String.fromCharCode(c);
            i++;
        } else if ((c > 191) && (c < 224)) {
            c1 = utftext.charCodeAt(i + 1);
            string += String.fromCharCode(((c & 31) << 6) | (c1 & 63));
            i += 2;
        } else {
            c2 = utftext.charCodeAt(i + 2);
            string += String.fromCharCode(((c & 15) << 12) | ((c1 & 63) << 6) | (c2 & 63));
            i += 3;
    return string;
阅读原文:点击这里
该文章在 2026/8/17 17:51:30 编辑过
