[求助]hMailServer提示权限不够,无法创建对象,错误码:573
Ccoffee
2010年7月8日 11:32 本文热度 30011
Question:
When I use CreateObject to create an instance of hMailServer.Application, I get an permission denied error. I'm using IIS6.
有用户反馈手工安装点晴OA系统,提示:“Email子系统组件未正确安装,无法创建邮件对象,请联系管理员解决!错误码:573 ”
该文章在 2013/4/7 10:22:50 编辑过
全部评论2
Ccoffee
2010年7月8日 11:34
answer: you need to tell windows that iis has the permissions to create instances of the hmailserver com object. do this: 1) from the windows control panel, go to administrative tools 2) open up component services 3) expand component services folder 4) expand down to computers | my computer | dcom config 5) right click on hmailserver and select properties 6) select security tab 7) under launch and activation permissions, select customize and click edit 8) make sure your anonymous iis user has local lauch and local activation permissions set to allow. •working with windows 2003 server with iis6 •this method did not working with (vista iis7)
该评论在 2010/7/8 11:34:05 编辑过
2013年4月7日 10:20
图形化教程参见以下帖子:
